06-10-2023, 09:14 PM
(04-21-2023, 01:57 PM)Davidsoy napisał(a): Hello! I'm sorry to hear about the issue you're facing with your device. It's frustrating when something you purchase doesn't work as it should. As for your problem, it's possible that there are positive words that start with s and a simple solution to this without having to reflash the firmware. One thing you could try is resetting the device to its factory settings. Most devices have a reset button that you could press and hold for a few seconds until all the lights turn off. Then, try connecting the device to your WiFi network again. If this doesn't work, then unfortunately, you may have to wait until you can purchase a USB serial interface to try flashing it. Hope this helps!
Thanks for your help. However, this is a POLISH forum! Why did you choose to speak English instead??
