RELAY AFTER START-doesnt working
Hi ,
I have got a problem with funkcion RELAY AFTER START.
All boxes(ON) unchecked but after restart ,all rellays ON.
I did try check/uncheck each of outputs and of course save it.But still same-after start all relays ON :? ...
Can somebody help me ,please?
Propably you set some in events config, check it. Attach print screen from events config
Iam stupid :roll:
You are right.Problem solved.Thank you.
I would like to ask you one more question.
It is possibilitty to set up one of the output as a Differential Temperature Controller?I like to use it for switching pump in sollar system...I have no Idea but maybe you got some...
Or its possible only monitoring temperature of solar cells and tank ,and for pump swittching I have to use it another device...
In actual software isn't posible, but new version 3.08 it will be add difirential measure in events config.
Its new software apllicable only for HARDWARE V2.0?
I have got V1.2 so there is no way to do it difirential measure-am I right?
for versions 1.2 probably will also be
My last question is-when will be firmware 3.08 available?
3-4 weeks
Czy prace nad nowym softem dobiegaja konca ?
bedzie obsuwa z 2 tygodnie
