07-09-2024, 03:37 PM (Ten post był ostatnio modyfikowany: 07-22-2024, 01:52 PM przez dusanstr.)
Well thank you
Solar panels: 3960 Wp, Solar Controller: EPEVER-150VDC/80A, Inverters: Household / Victron 5000 VA/24V, Water heating / Victron 3000 VA/24V, Li-ion battery: 18650 56P/8S + Li-ion 50Ah 3P/8S + Li -ion 150Ah 8S = 31.6V/440Ah (LK3, LK3.6, LK3.8)
Well thank you
Well thank you
Thanks for the answer.
Have a nice day.
Check if your LK3 is reading the current as unsigned; changing it to signed (INT16) should display negative values correctly. Some BMS systems also use a separate register to indicate charge or discharge mode. If so, you may need to manually adjust the sign based on that register. Baldi’s Basics Plus
Well thank you
Thank you
09-13-2025, 05:28 AM (Ten post był ostatnio modyfikowany: 09-13-2025, 05:28 AM przez 205theost.)
Interesting issue! To tackle the negative current display in your BMS Modbus setup via LK3, double-check your register mapping. Ensure you're interpreting the value as a signed integer. Some systems might require bitwise operations to handle the sign properly. Perhaps playing Snow rider while troubleshooting for a mental break might help you see new insights.
