BMS Li-ion battery via Modbus
Well thank you
Well thank you
Well thank you
Well thank you
Thanks for the answer.
Have a nice day.
paper io
Well thank you
Make sure the Modbus register for current is correctly interpreted as a signed value (e.g., 16-bit signed integer) to properly display negative current during battery discharge.
To correctly display negative current during battery discharge, verify that the Modbus register for current is correctly translated as a signed number (e.g. a 16-bit signed integer).
escape road
