Liczba postów: 64
Liczba wątków: 16
Hi,
i would like to ask you for a delay to enter the output or events ..
or the input delay (ds1 out1 = 1)
thx your job
Liczba postów: 2,357
You want to set out about 5 minut later than ds1
Liczba postów: 64
Liczba wątków: 16
yes, or
when out1=1,than 5minut later out2=0..
just delay outputs
Liczba postów: 64
Liczba wątków: 16
is it possible to improve LK3 with this function in event or option time for out ON/OFF? (the function can be used as a security element)
example pumping water:
INPD1 = low level
INPD2 = hight level
when INPD1 = 0 => out1=1 (start pump)
when INP2 = 1 OR (INPD1 = 1 max 30s) => out1=0 (stop pump)
OR
when INP2 = 1 OR (out1=1 (max 30s)) => out1=0 (stop pump)
thanks for the reply
we will try to add in the next version
