10-02-2012, 02:48 PM
Załączam instrukcję , aplikację do upgradu + firmware v1.2, który zmienia numeracje wyjść z 0-7 na 1-8 i dodaje ustawianie portu www na domyślny po resecie ustawień
instrukcja -
poe_switch_ver_1_2.bin (Rozmiar: 222.59 KB / Pobrań: 596)
aplikacja -
POE_SWITCH.exe.zip (Rozmiar: 803.4 KB / Pobrań: 1,032)
firmware -
instrukcja_switch_1_0_pl.pdf (Rozmiar: 703.23 KB / Pobrań: 1,324)
Jak zrobic upgrade jest opisane na końcu instrukcji.
Obsługa VLAN i QoS, bedzie dodawna w kolejnych wersjach oprogramowania.
I dodam że uklad switcha charakteryzuje się poniższymi cechami.
Green Ethernet features include:
Link-On and Cable Length Power Saving
The chip provides link-on and dynamic detection of cable length and dynamic adjustment of power required for the detected cable length. This feature provides high performance with minimum power consumption.
Link-Down Power Saving
The chip implements link-down power saving on a per-port basis, greatly cutting power consumption when the network cable is disconnected.
Features
Integrates eight 10/100 transceivers and nine MAC units for 10Base-T and 100Base-TX
Embedded SRAM for packet storage
On-chip 1024-entry look-up table in direct mapping mode
Embedded 16-entry CAM for hash collision mapping
Provides read/write access to look-up table entries via SMI interface
Provides non-blocking wire speed reception and transmission
Flow control fully supported:
Half-duplex: backpressure flow control
Full-duplex: IEEE 802.3x flow control
Optional loop detection function with an LED to indicate the existence of a loop
LEDs blink upon reset for LED diagnostics
Optional crossover detection and auto correction for plug-and-play
Fully compliant with IEEE 802.3/802.3u.
Optional Forwarding/Filtering reserved control frames (DID=0180C2000003~0180C200000F)
Optional Broadcast Input/Output Drop flow control
Optional maximum packet length 1536/1552 Bytes
Green Ethernet Features
Supports QoS function:
QoS based on: (1) Port-based priority (2) 802.1p VLAN tag (3) DiffServ/TOS field in TCP/IP header (4) IP address
Supports two-level priority queues with various weighting ratios
Queue service rate based on weighted round robin algorithm
Optional auto turn off Flow Control for 1~2 sec to avoid head-of-line blocking
Flexible 802.1Q port/tag-based VLAN.
Optional 802.1Q tag-VID aware function
Optional VLAN Ingress Tag Admit Control
Optional VLAN Ingress Member set filtering
Optional ARP VLAN for broadcast packet
Optional Leaky VLAN for unicast packet
Optional 802.1P/Q tag insertion or removal on per-port basis (egress)
instrukcja -
aplikacja -
firmware -
Features
