Email subject for events
Hello,
1.
I would like to buy V3 and need to know if it´s possible to set different email notification (subject and body) for each event.
In V2 there is a text for each event. I have to recognise which event it is when I receive the email.
2.
Which temperature sensor do you recommend? Does the AM2320 works great or do you recommend something like PT1000 instead?
Thank you.
Hi
ad1.Subject and boody are te same for each event but on end email is additional info about with event send email.
ad2.To measur same temperature DS18B20
Thank you,
Ok I'll take DS18B20. Does it work in RJ11 or do you recommend the classic pin type?
do you plan to implement something like visible graphs of measured values (temperature)?
DS18B20 on Rj11
visible graphs maby we add when implement supoprt for microSD card write/read
