Possible upgrades events
Hi,
it would be can be upgraded to the event ??
1) A mathematical function
2) "The final event" could be used in other logic(event) (it would solve the problem with missing diff temperatures)
3) EVNT(time by scheduler) could specify interval (start, stop)
Thanks for your response, KollnjakSmile
kollnjak napisał(a):Hi,
How do you see the operation of these mathematical functions? Explain more
kollnjak napisał(a):2) "The final event" could be used in other logic(event) (it would solve the problem with missing diff temperatures)
We'll think about it, but diff will be add soon (week)
kollnjak napisał(a):3) EVNT(time by scheduler) could specify interval (start, stop)
You can set the start and stop times of the EVENT in the scheduler
1) Example T1 + T2 < T1 - T3
T1 + T2 < T4 +T3
2)Example Diff1 < 10 and Inpd1 =1 -> A, A and EVNT1 -> OUT1
T1 < 10 and T2 > 20 -> B, B nand EVNT2 -> OUT2
Hi,
Should it make a virtual output in EVENT?
Or is there any other way to make an event from three (and more) input variables?
Thx for yout aswer Kollnjak
1)Now in DIFF1 and DIFF2 we add + or -
2)We add some virtual output like A,B,C,D
It should be in new firmware about 1-2 days
in this soft http://tinycontrol.pl/forum/viewtopic.ph...746#p10746
You have:
- diff1 i diff2 + or -
- in events we add 4 additional event4-8 as virtual outputs.
Thx for your good jobSmile
Hi,
I uploaded soft 1.38b, but it was bad
1) I do not see DIFF + and - .. Actulane are DIFF set to + only
2) I do not see virtual outputs
I can deplore something bad. please help
.jpg   problem evnt.jpg (Rozmiar: 295.75 KB / Pobrań: 2,908)
clear cache in web browser
Thank you for your advice, I'll see you all ..
I have another question, do you manually turn ON/OFF virtual outputs (EVNT1-EVNT8) ??
