[EN] PT1000 reads wrong numbers
Maybe it has been already there, but I can't read polish and automatic translators are trash.
I have Lan controller: HW:1.1 SW:3.11 S/N:2104
Most of the functions are working just fine. Not mentioning wrong datatypes at snmp output, but I can live with that.
Recently I have added the PT1000 themperature sensor.
http://www.gme.cz/img/cache/doc/530/110/...heet-1.pdf
Brief test by multimeter shows correct resistance at ambient temperature. But after connecting to correct pins the readings are just wrong. For the ambient temp. the read is off by about 10deg.C. I can't however remember which way. For temp above 150deg.C it reads like 96deg.C. I can't figure out what is wrong.
in ambient temp. set kalibrate
