Lan Kontroller SMS (the web) api support ?
LanKontroller product to the "Events Config" from the internet, SMS api support do you think?
SMS API works as in the example :
1-) http://api.netgsm.com.tr/bulkhttppost.a ... 0120202321");
2-) http://gateway.mobilus.net/gateway.asp? ... sage=$body");
example
$api_user = "wifianten";
$api_password = "****";
$api_id = "SISBILTEK";
$body = rawurlencode($body);
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, "http://api.netgsm.com.tr/bulkhttppost.asp?usercode=$api_user&password=$api_password&gsmno=$mobile&message=$body&msgheader=$api_id&startdate=300120121721&stopdate=300120202321");
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
$res = curl_exec($ch);
curl_close($ch);
or
http://www.bulksms.com/int/docs/eapi/
bulentkusva napisał(a):LanKontroller product to the "Events Config" from the internet, SMS api support do you think?
IF you have SMS server which support GET/POST messages it should work with current version, but for configuration as in your example is no space in flash.
But it is possible to do by intermediary server as thingspeak.com for exmaple.
If you need really reliable solution, next weeks will be available new GSM Controller version, with features similar as Lan Controller but with GSM communication on board.
I test http://bulksms.vsms.net:5567/eapi/submis...n&password=
abcd1234&message=Hi+Mom+%26+Dad&msisdn=44123123456,44123123457 and its works
When we write in a web browser running
http://api.netgsm.com.tr/bulkhttppost.as...ssage=test message&msgheader=SISBILTEK
working in this way
Can not run in HTTP client?
what exactly you typed in a URL? Show print screen
EXAMPLE : http://api.netgsm.com.tr/bulkhttppost.as...ssage=Test Massage&msgheader=SISBILTEK
show print scren how you typed it on the Lk page
info@tinycontrol.pl
Did I send an email reached?
send to me private masage
