NTP impossible set, Monlan1
Hi,
I try to set NTP in the Date and Time page but there is no possibility to save this on, when I reboot or take power off on or change page, the set return in manual, also it is impossible to put new NTP server name, impossible to save configuration, after change page and return, the configuration return to default server name.
Anyone know the problem ?
The current version on Monlan1 is 2.13
Many thanks
> also it is impossible to put new NTP server name, impossible to save configuration, after change page and return, the configuration >return to default server name
you must click "save config " button below Trap Enable and other
>I try to set NTP in the Date and Time page but there is no possibility to save this on, when I reboot or take power off on or change >page, the set return in manual
you must click second "save config " button below Data and Time
