Liczba postów: 3
Liczba wątków: 1
Hello. I have Lan controller. But It doesnt boot. Its only green led blinking . No eth answer ping, arp etc. all tftp update fail.
Is any chance to recovery board to normally function ??
Thanks for help.
Liczba postów: 2,350
grenn led blink, means that is it in bootloader mode. You try simply put by tftp? What soft was before upgrade?
Liczba postów: 3
Liczba wątków: 1
It have a "home" version 3.21. i tryied put in controler "isp" version. But always fail start upload by tftp (connection timeout) . Now controler wont respond anyway.
If you have enabled DHCP, use standard IP 192.168.100, if not, use last IP.
Liczba postów: 3
Liczba wątków: 1
Thanks. It works with my IP and WinXP.
