1 godzinę temu
Are you ready for a heart-pounding experience that will leave you checking every corner of your room? Do you enjoy the thrill of being hunted, the adrenaline rush of solving puzzles under pressure, and the satisfaction of outsmarting a seemingly unstoppable foe? Then prepare to enter the terrifying world of Granny!
This isn't your grandma's house. This is a place of shadows, creaking floors, and the chilling presence of Granny, a sinister old woman with a penchant for bats, shotguns, and keeping unwanted guests… permanently.
1. What is Granny? A Descent into Horror
Granny, developed and published by DVloper, is a first-person survival horror game that throws you into a nightmare scenario. Trapped in a dilapidated house, you have five days to escape Granny's clutches. But beware, she hears everything. A dropped object, a creaking floorboard, even a whispered breath can alert her to your location.
Released on Android and iOS in November 2017 and later on PC, Granny has become a staple in the mobile horror gaming scene. Its simple premise, combined with genuinely frightening gameplay, has earned it millions of downloads and a dedicated fanbase. The game’s success led to sequels and inspired countless other horror games, solidifying Granny’s place in horror gaming history.
2. Gameplay: A Test of Stealth and Survival
The core gameplay of Granny revolves around stealth, puzzle-solving, and resourcefulness. You start in a locked room, with only your wits and a few hidden items to aid your escape. The goal is simple: find the necessary tools and keys to unlock the front door within five days (represented by five in-game lives).
But here's the catch: Granny is always lurking. She patrols the house, listening for any sign of your presence. If she catches you, it's game over, and you'll wake up back in the locked room, one day closer to your doom.
3. How to Play: Your Survival Guide
So, how do you survive Granny's house of horrors? Here’s a comprehensive guide to get you started:
Understanding the Environment:
The house is your battlefield. Familiarize yourself with its layout, hiding spots, and potential escape routes. Pay attention to where items spawn, as they tend to be in the same locations each playthrough. Look for:
Hiding Places: Under beds, inside closets, and behind furniture. These are your safe havens when Granny is near.
Items: Keys, tools, weapons, and puzzle pieces are scattered throughout the house.
Interactive Objects: Doors, drawers, cabinets, and even loose floorboards can hold secrets.
Mastering Stealth:
Stealth is your greatest weapon. Here are some tips to stay quiet:
Crouch: This significantly reduces your noise level. Use it whenever you're moving around, especially in Granny's vicinity.
Avoid Dropping Objects: If you accidentally drop something, pick it up immediately! The sound will alert Granny.
Listen Carefully: Pay attention to the sounds around you. You can often hear Granny approaching before you see her.
Gathering Resources:
Finding the right items is crucial for your escape. Here's a list of common items and their uses:
Keys: Unlock doors and chests. Look for keys labeled with colors or specific locations.
Hammer: Used to remove wooden planks blocking doorways or windows.
Crank Handle: Operates the well in the backyard, which may contain a valuable item.
Shotgun: A powerful weapon to temporarily stun Granny. Requires shotgun shells. (Use with extreme caution!)
Crossbow: Similar to the shotgun, but uses tranquilizer darts.
Puzzles: These can be solving codes or finding pieces that are necessary for you to go forward.
Outsmarting Granny:
While you can't kill Granny, you can certainly outsmart her:
Distract Her: Throw an object in one direction to lure her away from your intended path.
Use Weapons Wisely: The shotgun and crossbow can stun Granny, giving you a precious few seconds to escape. However, using them carelessly will only attract her attention.
Learn Her Patterns: Granny has predictable patrol routes. Observe her movements and plan your actions accordingly.
Understanding Difficulty Levels:
Granny offers several difficulty levels, allowing you to tailor the experience to your skill level:
Easy: Granny is slower and less attentive.
Normal: A balanced experience.
Hard: Granny is faster, more alert, and the house is darker.
Extreme: The ultimate challenge. Granny is relentless, and resources are scarce.
Practice: Granny doesn't attack, allowing you to explore the house and learn the layout without fear.
4. Tips and Tricks for Granny Survival
Ready to take your Granny game to the next level? Here are some insider tips:
The Well is Your Friend: Don't forget to check the well in the backyard. It often contains valuable items, but be careful, as Granny can sometimes lurk nearby.
Use the Environment to Your Advantage: Barricade doors with chairs or other objects to slow Granny down.
Headphones are Essential: Playing with headphones will allow you to hear Granny's footsteps and other important audio cues, giving you a significant advantage.
Don't Be Afraid to Experiment: Try different strategies and approaches to find what works best for you.
Check Behind Paintings: Some paintings hide secret compartments containing useful items.
Learn Granny's spawn points: After you are caught, Granny will spawn in a specific location, you can keep track of her movement and find the best time to move.
Crouch and walk at the same time: This allows you to move at normal speed while making little sound.
Don't stay in one place for too long: Granny patrols the entire house, so staying in one spot will make you an easy target.
Use the music box: The music box will attract Granny to it. Use this to your advantage to make her go to a different location, or put her into a trap.
Use the car battery to go to the back yard: One of the exits of the game is located at the back, which you can only access after you power up the car.
Explore the attic: There is an attic in the house that can be accessed through a narrow passage. This is also another good hiding place.
5. Dare to Enter Granny's House?
So, are you brave enough to face Granny? Download the game today and test your stealth, puzzle-solving, and survival skills. Just remember, she's always listening…
Share your Granny experiences in the comments below! What's the scariest encounter you've had with Granny? What are your favorite strategies for survival? We want to hear from you!
Mastering Stealth:
Outsmarting Granny:
