IP Power Socket 5G10A HW:1.2 SW:6.01
Hi,
I have the above ip power controller, bought a few years ago but never used.
Was on SW 6.01 and upgraded via TFTP to version 6.09 before put to service.
Unfortunately, it seems that the firmware is for version 2 of the controller, as i have lost communication with it.
Fortunately it still goes into TFTP mode
Would somebody be kind enough to supply me with firmware suitable for this interface? It is HW version 1.2
Thank you
(03-28-2023, 02:58 PM)SDA napisał(a): Hi,
Would somebody be king enough to supply me with firmware suitable for this interface? It is HW version 1.2
Thank you
.zip   lan_module_ver_6_02.zip (Rozmiar: 282.96 KB / Pobrań: 567)
unzip and put
Thank you very much, yes working now.
As to the reason for wanted to upgrade from Ver. 6.01 was  when I power-cycle the interface, I loose previous settings, and outputs are in the OFF status.
Upgrading to V6.02, the problem remains.
Eg - Set outputs all ON and after power-cycle all is OFF.
Thank you
Never mind,
From the Events config sub menu, if the ON delay is set to ON, output settings are stored.
