Liczba postów: 6
Liczba wątków: 3
Is it possible to disable all relays going on/off when Lan Controller is connected to the power for the first time.
This behavior can stall some electrical equipment we use.
Thanks!
Liczba postów: 2,358
You probably have set up an event in an array of events, possibly due to the TEMP sensor? How do you run a module temperature starts at 0 or negative, and after a few seconds to stabilize. If you have an event included in the TEMP, enter values in the lower boxes below 0.
Attach "config events" print screen
