Relay state problem if device booting
Dear man,
I would like to consult problem with your LAN controller modul. We are using some these moduls with expansion relay modules in our DC power supply systems. 2 relay we are using to temperature control (heating or cooling) and three relay we are using for remote reboot connected devices. If LAN Controller boot it change relay state for some second. Its problem for us because it means reboot connected devices. So my question is - can you change it in next firmware relase please?
Thank you.
Lukas
1.Send PrintScreen with the settings from the "Events config".
2. What two outs you use to temperature control ?
