SMTP without authorization, different text mail
Hello
how to set the SMTP server when not supported authentication.
It would be possible to add I/O inputs of the possibility of sending another text for state LOW and other text for state HIGH.
Thank you.
borgmcz napisał(a):Hello
This option will be add in next software, maby next day.
borgmcz napisał(a):It would be possible to add I/O inputs of the possibility of sending another text for state LOW and other text for state HIGH.
Now, if you have LOW state, on end mail you have 0 and HIGH state you have 1
this soft http://tinycontrol.ats.pl/forum/viewtopi...f=2&t=2567 supports SMTP server without authentication. In email options leave blank the "user"
wilkxt napisał(a):this soft http://tinycontrol.ats.pl/forum/viewtopi...f=2&t=2567 supports SMTP server without authentication. In email options leave blank the "user"
smtp with authorization - works OK (seznam.cz)
smtp without authentication - works OK (local ISP)
wilkxt napisał(a):Now, if you have LOW state, on end mail you have 0 and HIGH state you have 1
This is not user friendly.
A better choice would be the possibility of a separate state for the text as HIGH as a separate text for state LOW.
You will get the opportunity to understand messages such as these:
Work on the battery
Working from the AC network
pump works
pump off
operation OK
battery fault
You can obtain a clear message to the user.
