Maximum number of relays
Hello all,
I'd like to ask, if 5relays (1on board + 4relays board) is maximum I can run with one LanKontrol. If there is a possibility to connect one more relay as a Output5, how can I connect it.
Thank you in advance.
Regards
MaX
max 10
1 lk board out1+ 1 LK out5 in board
4 external OUT 1-4 releys on IDC10-2
4 external PWM 0-3 releys on IDC10-1
out 5 simple connect 2 wire for out5 and gnd and connect to the relay coil based by power you used
for pwm use releys as out or use boards https://www.ledats.pl/en/kontrolazasilan...ay-tr.html
if you use multiplexer CD74HC4067 [DIY] 4 uotputs control 16channel --> based by arduino  ==> max 34 releys or 96 bistable Smile
[Obrazek: 31-492-3.jpg]
(09-14-2022, 02:36 PM)stAch napisał(a): max 10
if you use multiplexer CD74HC4067 4 uotputs control 16 -- based by arduino  ==> max 34 Smile[Obrazek: 31-492-4.jpg]
Hello stAch,
thank you for reply.
I wonder if there is product for "4 external PWM 0-3 releys on IDC10-1" such as https://tinycontrol.pl/en/accessories/bo...-board-4x/... or I have to put it together myself.
Have you seen any prepared solution for IDC10-1 ?
Best regards
MaX
(09-14-2022, 02:45 PM)maxvatar napisał(a): Hello stAch,
Best regards
MaX
or try this board for all 10 releys output https://www.ledats.pl/en/kontrolazasilan...r-lk3.html all external board in shop is redy tu use - you need only LK3 board - mount and ready
https://www.youtube.com/watch?v=kEnqTzG0U8s -pwm external board in run
Thumbs Up
Best regards
MaX
Great. Thank you for hint.
Have a nice one.
