Epever XTRA series
Hello, can you tell me if your LanKontroler (V3.7 + plus modbus module) can communicate with the above series of chargers?
Are they compatible with the Tracer series?
As it seems that the Tracer series is being phased out, and replaced the the Xtra series.
Thank you
In the modbus options, knowing the register addresses, you can define yourself what you want to read from the device. Do you have a modbus description for this device?
Thank you for your reply.
Searching, I found this : https://github.com/plopp/python-modbus-e...readreg.py link.
It seems that the register addresses are the same.
I do have a tracer series charger, but I will order an xtra series unit for redundancy.
I will post the outcome.
Thanks again
