09-30-2021, 07:36 PM
1) When working with many LK3s I can't tell which is which unless I switch to Network to see the host name/IP.
Please put the host name of the device in web title. All the tabs I have are called the same and I don't know which is which. All my tabs are called "LK3 VPanel". Ideally you could give it a name that isn't a host name, like a friendly name so I know which is which after DHCP gets hold of them.
2) LK3 Tools work well but the "find" function is bound to the primary address, so it only finds LK3 devices that have the same subnet as the host doing the searching. I have a PC that has 192.168.220.2 and 192.168.221.2 (same interface), both having devices on them, 220 has PCs and consoles and 221 has LK3s. When first started and DHCP gives them 220 IPs, I can find them but when I give them 221.X IPs it won't. Perhaps a settings section where I can specify what to look for? Of note is that you CAN flash them if you manually input the 221.X IP in the flasher.
