SONOFF and LK3
Hi ...
I've bought here : https://www.banggood.com/DIY-Wi-Fi-Wirel...rehouse=CN .
It could be joined to LK3 ???
George.
SV2BZQ post_id=15581 time=1513689165 user_id=6105 napisał(a):Hi ...
George.
Yes, but you have to put Sonoff Tasmota firmware and configure for further work.
We sell prepared Sonoff Basic with this firmware and have manual how to setup.
George.
Ok thank you for answering it ....
George.
Ok i put Sonoff Tasmota firmware all ok and I can handle it through via mqtt.ats.pl .
But I have not managed to work it via LK3 . :oops:
Some help with the LK3 setup ???? :?:
Thanks for the time ..George
set sonoff out by LK3.
LK3 setings:
1.In http client set sonoff IP and remote url: ay?o=1
2.Do not enable http client send, if you enbale it, sonoff out will be swithced on/off by http client time
3. In events set out as http client
Now if events occur then set url by http client to sonoff
wilkxt post_id=15593 time=1513883306 user_id=61 napisał(a):set sonoff out by LK3.
LK3 setings:
Thank you for the immediate answer .
All ok .
2 questions :
1) since it uses http client for WR-01 how to update the thingspeak since there is no other http client in LK3 ?? :?:
2) if you can change from out2 to outxx ? :?:
George.
SV2BZQ post_id=15595 time=1513943487 user_id=6105 napisał(a):1) since it uses http client for WR-01 how to update the thingspeak since there is no other http client in LK3 ?? :?: +
Yes, it is impossible now, but, next soft we add additional http client settings to do this
SV2BZQ post_id=15595 time=1513943487 user_id=6105 napisał(a):2) if you can change from out2 to outxx ? :?:
change where?
Hi again.
We have information about this ???
George.
We're still working on a new soft
wilkxt post_id=15629 time=1517211869 user_id=61 napisał(a):We're still working on a new soft
Τhank you for your immediate answer .
I wait with anguish .
George.
