LANController V3, 1Wire DS18B20 and splitter
kollnjak napisał(a):Hi,
this firmware (V.1,35b) is next oficial beta version for LanControler V3? Why is it here in this topic?
Thx your answer
kollnjak
No, is test software, official beta version will be add soon
aarrspg napisał(a):With this firmware the LANController does not boot
I check this sof and is ok, boot normaly, try restart to default settings
Hi,
I think I have a similar problem..After connecting two and more DS18B20 across the splitter I crash the display (visibility) on the status page ..,
this plugged I used at Lancontroler V2 and everything was OK ..
I suspect that I was slightly affected by the RJ12 connector compared to V2..
Kollnjak
I tried the firmware with the other LANController and now I have two LANControllers that don´t power up :evil: . How I reset them? Think that the devices does not run.
Regards.
maby LK is in bootloader mode put this firmware by ftp http://tinycontrol.pl/forum/viewtopic.ph...024#p10686
I put the LANController in bootloader mode, updated it with firmware 1.36b1 and nothing happens. The device doesn´t link.
Hello,
Try LK to find IP scan if you do not say so try:
1) connect only PC and LK3 (without router and your pc must be in the same network eg ip address 192.168.1.25)
2) mode bootloader (you have to get jumper)
2) try to upgrade the firmware via ftp (as it is written here in the manual), recording firmware must have the extension .bin!!
3) ftp -> LK3 IP address 192.168.1.255
This procedure worked for me.
Be sure to agree this procedure with the "wilkxt" administrator Smile
kollnjak napisał(a):Hello,
Procedure is OK
The LK3 IP address may be the same as it was set earlier
You can watch LK activity (if it start bootloader or not) on your computer via the terminal. You need a USBUART (3,3V) adapter and some terminal program, such as a hyper terminal, realterm or something else.
USBUART e.g http://kamami.com/usb-uart-rs232-convert...results=12
This is the procedure I followed, but the LK didn´t boot anymore.
Watch LK activity (if it start bootloader or not) on your computer via the terminal
