LAN Controler V3 does not work.
Hello,
I bought Lan Controller V3. After turning on everything worked OK, but after setting the remote management over mqtt.ats.pl device has been restarted and no longer works. I am trying to connect over www (192.168.1.100) and failed. Instead of the web interface to see the report, 404: The requested file cannot be found. Please do you have any recomandation how to fix the problem? I already tried to full resset but unsuccessfuly.
Thank you for any help.
Hi
put this new software to LK3 http://tinycontrol.pl/forum/viewtopic.php?f=28&t=6024
instruction how tu put new software http://www.tinycontrol.pl/tinycontrol/en..._A6_EN.pdf
