05-29-2012, 11:08 AM
		Hi,
I need to set the scheduler for same day, example out 0 on at Monday and Tuesday 8.30, but there is not possibility to change in manual set the day, only the data and time not day.
If I try to set NTP, seems that it is impossible change the NTP adress, when I take out power and than restart the old adress return.
firmware version 2.13
Please I need you help to set correctly the scheduler
Thank you
Thank you
