ograniczenie 1-wire do 4 czujek ds18b20
kilka dni bedzie wersja home z 6 czujnikami
hi,
I tried to translate some parts of this post, but dont understand all :-(
My questions are:
if I have already 4 ds18b20 connected, is there any possibility to change the order / numbering?
(without reset to default)
and since which version we should have 6 ds18b20? (only at the home version?)
same for DTH11?
Thanks
Shorty
shorty1965 napisał(a):hi,
My questions are:
same for DTH11?
Thanks
Shorty
1. 6 ds18b20 and DTH11 are only in HOME version, standard version has only 4 DS18b20 and no DTH11.
2. The order is assigned at startup LK, and is fixed (for the same sensor) depends on the number of individual sensors. If you replace the sensor on some different sensor positions may change.
Hi tomek
is there any newer document regardind the new inputs e.g. INP12?
I have now DHT11 connected, and inp 12 shows 171!?
where is inp12 pin?
BR
shorty
.png   inp12.png (Rozmiar: 235.56 KB / Pobrań: 4,729)
.png   inp12.png (Rozmiar: 235.56 KB / Pobrań: 4,794)
.png   inp12.png (Rozmiar: 235.56 KB / Pobrań: 4,789)
INP12 is first pin in IDC10 connector, look this http://tinycontrol.pl/forum/viewtopic.ph...6912#p6912
You may connect voltage signal from 0 to max 3,6V
hi
do you have any recommandation for the usage of INP12, with sensor can be used?
and why it shows in idle 173 A? should I make a brigde to ground in the meantime?
what kind of hall sensor can be used for power measurement?
is there no newer document for the new features?
thanks
Shorty
shorty1965 napisał(a):do you have any recommandation for the usage of INP12, with sensor can be used?
No, but we plan use one from allegromicro http://www.allegromicro.com/en/Products/...r-ICs.aspx
shorty1965 napisał(a):and why it shows in idle 173 A? should I make a brigde to ground in the meantime?
Yes
shorty1965 napisał(a):is there no newer document for the new features?
No
Hi,
could it be that there are troubles with 5 DS18B20 sensors at home version 3.08?
it resets every few minutes, and all relay´s are switching for approx. 1 sec.
the state shows for a short time 0 degree for all 5 sensors.
About INP 12,I made a bridge to ground, but still it shows some value between 3 and 10 A
BR
Shorty
shorty1965 napisał(a):Hi,
BR
Shorty
Do you stil have problem with sensor DS18b20 in soft 3.09?
Hi again,
about ds18b20 ordering
"The order is assigned at startup LK, and is fixed (for the same sensor) depends on the number of individual sensors. If you replace the sensor on some different sensor positions may change."
how exactly can I change now the numbering, e.g. when i want position 4 as first sensor?
all sensors are already used.
thanks
shorty
