Relay direct control via HTTP
ok, I check it next week
You test it directly from LAN network or by WAN (router)?
Directly from LAN... Do you see this problem too?
Ondrej
I test it from firefox and chrome and is OK, how you send command, from webbrowser or another?
Yes, from webbrowser, I always prepare http string in notepad and using copy & paste put it into address line in browser and execute with enter. I tried it in firefox v19 and Explorer 9 and the result is the same. Should I try something so we both are sure there is no bug in my testing?
Ondrej
Ok, upgrade this
.bin   lan_module_ver_2_40.bin (Rozmiar: 324.62 KB / Pobrań: 193) soft 2.40 and test
Hello Tomek,
thank you for your SW 2.40, I upgraded and it works! ;-) Where was the problem actually?
But now, I see anothe bug - NTP is not working, I tried my NTP I use in LK with SW 2.20 (147.228.57.10)
but it does not sync.
Sincerely
Ondrej
In LK with soft 2.2 NTP works or not?
In 2.20 works, in 2.40 not.
how 2.39 ? Works NTP?
