MODBUS ADRESSES
Hi,
Is it possible to modify addresses in LK4 MODBUS SERVER ? I need to integrate it into a hypervisor that has fixed addresses and cannot map.
THX
(09-16-2025, 12:02 PM)Pipounz napisał(a): Hi,
THX
Hi
You mean about MOdbus TCP? There are addresses which are connected with our sensors.
You should be able set this address on your PLC controller.
Hi,
Yes i meaned MODbus TCP, I didn't use a PLC controller, i use a VMS and i would like to interface LK4 instead of expensives Advantech or Moxa products, unfortunaletly the sofware only connect on fixed adresses without any possibility to custom. I just need to have INPD states, but as entry 1 the address is 0001, then i have to create 1999 inputs in the VMS to have INPD1 state ;-)
Thx
Integrating LK4 MODBUS SERVER into a hypervisor with fixed addresses can be tricky. Modifying addresses directly within LK4 might not be straightforward. Explore if LK4 offers address remapping or offset configurations. Perhaps, external tools could mediate between the hypervisor and LK4, like a fun challenge in Slope Game where you navigate obstacles. Consider alternatives to ensure smooth communication, especially if avoiding address conflicts is crucial for your setup.
That's a tricky situation! I haven't worked directly with LK4 MODBUS SERVER and hypervisors, but it sounds like you're facing a remapping challenge. Maybe there's a workaround involving virtual addressing within the hypervisor itself? It's a bit like navigating a complex slope and needing to find the right path. Sometimes you just have to find a way to go around the obstacle. You might try Googling it, like when I tried to find the best way to beat my son at Snow Rider 3D. I had to dig deep! Good luck finding a solution.
I was trying to get an old temperature sensor to talk to a modern PLC. It was pure frustration, data misalignments everywhere! Data formats were incompatible, and I had to write a custom translation layer. Finally, getting the sensor was like a Slice Master in getting the right cuts on the final product, that’s when I truly smiled.
Hey! Hmm, never messed with LK4 specifically, but that fixed address thing sounds like trying to get Drive Mad to run perfectly on a really old phone, haha. Painful! I'd check if LK4 has any config files you can directly edit, or if the hypervisor has a way to "trick" it with a virtual address space. Good luck!
