How to set up INPA1
I need to measure voltages from 0V to about 130V, so I am using resistors divider ( R1 =47k, R2=1k ).
How should I properly set up INPA1 in LK4? Or into which input should I connect the measured voltage?
Thank youi for help
Thank you for your reply. I have  solved it.
You may be a greater expert (than me -  I am just a beginner) on using LK4 - .
Can you please help me with setting up Email in LK4?
I set up the Email like this
https://preview.tinycontrol.pl/lk4/#/email
( with my credentials) but no emails arrive ( even if I  just use Test email sending option).
A also tried to use with my email server ( used with No encryption option ) but the same.
My network works, because the time is updated  via NTP server.
Do you have any idea what try?
Thanks for help
(01-09-2025, 11:09 AM)BMA napisał(a): Thank you for your reply. I have  solved it.
https://preview.tinycontrol.pl/lk4/#/email Stickman Hook
Thanks for help
Maybe it's your windows. Try reinstalling it.
