Is it possible to use LK to control power to boiler( not only when to start/ends it but continually controll boiler according to ,for instance, how much battery is charged? I think it is done PWM and SSR (relay) but not sure how much difficult it would be with LK?
Boiler controlling via PWM
02-27-2025, 11:01 AM
58 minut(y) temu
Rise to the top in Baseball Bros IO, where every victory, every home run, and every perfectly timed swing adds to your baseball legacy.
