How to set up INPA1
I need to measure voltages from 0V to about 130V, so I am using resistors divider ( R1 =47k, R2=1k ).
How should I properly set up INPA1 in LK4? Or into which input should I connect the measured voltage?
Thank youi for help
(12-21-2024, 07:35 PM)BMA napisał(a): I need to measure voltages from 0V to about 130V, so I am using resistors divider ( R1 =47k, R2=1k ).
Thank youi for help
Connect the measured voltage to the voltage divider (R1 = 47kΩ, R2 = 1kΩ). Connect the divider's output (junction of R1 and R2) to INPA1. Configure INPA1 as an analog input in LK4. Ensure the ADC reference voltage supports the ~2.71V max output from the divider and consider adding over-voltage protection.
Thank you for your reply. I have  solved it.
You may be a greater expert (than me -  I am just a beginner) on using LK4 - .
Can you please help me with setting up Email in LK4?
I set up the Email like this
https://preview.tinycontrol.pl/lk4/#/email
( with my credentials) but no emails arrive ( even if I  just use Test email sending option).
A also tried to use with my email server ( used with No encryption option ) but the same.
My network works, because the time is updated  via NTP server.
Do you have any idea what try?
Thanks for help
