03-28-2023, 03:44 PM
(Ten post był ostatnio modyfikowany: 03-28-2023, 04:14 PM przez SDA.
Powód edycji: Figured it out
Thank you very much, yes working now.
As to the reason for wanted to upgrade from Ver. 6.01 was when I power-cycle the interface, I loose previous settings, and outputs are in the OFF status.
Upgrading to V6.02, the problem remains.
Eg - Set outputs all ON and after power-cycle all is OFF.
Thank you
Never mind,
From the Events config sub menu, if the ON delay is set to ON, output settings are stored.
Thank you
Never mind,
