(10-10-2022, 01:09 PM)maxvatar napisał(a): Hello janekx,
I bought this https://www.victronenergy.com/accessorie...-interface. It should be connected to Victron CerboGX USB port. The other side should go to https://tinycontrol.pl/en/accessories/bo...odbus-rtu/ - I plan to connect only A+, B- (so without Rx, Tx, aux power +3.3V). I'll let you know, if it works.
Hi i setup Cerbo GX for NodeRED from 2.91 it is in update and now can send MODBUS TCP by LAN so only issue to find some MODBUS TCP clinet to PWM or level 0-10V to control. TinyControl is not modbus TCP client
 Right now i cant use RS485 or USB as both devices are on diferent site of house. But your try will be interesting as well fot other applications.
(10-10-2022, 05:11 PM)janekx napisał(a):(10-10-2022, 01:09 PM)maxvatar napisał(a): Hello janekx,
Hi i setup Cerbo GX for NodeRED from 2.91 it is in update and now can send MODBUS TCP by LAN so only issue to find some MODBUS TCP clinet to PWM or level 0-10V to control. TinyControl is not modbus TCP clientRight now i cant use RS485 or USB as both devices are on diferent site of house.
Or use LAN to RS485 and tinycontrol
