03-04-2013, 01:45 PM
I used the same scheme, it is standard 1Wire connection.
Problem is that the software shows 4 sensors.
1. When I connect 1 sensor it is ok and temperature is showed in first textfield.
2. When I connect 2 sensors, I see 2 different temperatures which is almost ok, but I can not recognize which sensor is which input. I am missing something, like assignment Inp6 to sensor Id XY, Inp7 to sensor XZ, ...
According to the software it should be possible to assign 4 sensors. I think that standard 1Wire has no limitiations to number of sensors.
3.But when I connect 3 sensors the LANController does not start at. Or better to say, the LEDS are shining but I can not access the webpage with control, or even ping it.
I think this is more software than hardware problem. Any suggestions, or versions where it works better?
