12-13-2012, 10:35 AM
wilkxt napisał(a):raptor napisał(a):ok, when I push on by scheduler, I must stop by scheduler (for sure), I understandNo, scheduler set out ON and events can OFF this out
wilkxt napisał(a):But if temp was above 16,4 (eg. 16,8) and next go to >=17,6, nothing hapend because temp never was below 16,4.I don't know, how is the temperature when scheduler START out0, I must stop by scheduler (for sure).
wilkxt napisał(a):You may set hysteresis to 0, but if inp8 wil be below 17 then out0 set ON, but you don't that? You want to set out0 ON only by scheduler(not event), and event have it OFF only when temp wil be above 17,6?
Tel me what is lowest temperatur on INP8?
I would like to maintain the temperature in the house was close to 17-18 ° C (0.5 ° C hysteresis) - heater always slightly overheated. It works wonderfully
But.
When I come home, and when I get up, I'd like to have more heat.
Then I manually switch to a different event (20 ° C + -0.5 ° C)
The overheating must be fully automatically, because, I may have work responsibilities and do not have to be at home. perhaps
if there was a trigger at 22 ° C which would say STOP, it would be pretty easy.
