LAN Controller V3 malfunctioning?
Hi!
I bought a LAN Controller V3 but I have the following problems:
- Powered by an 18Vcc AC/DC adapter, the voltage displayed in the STATUS menu is 13Vcc.
- The temperature displayed is 137 degrees celsius.
- I have measured the voltages on +5v pins and it is ok, but on +3,3V pins the measured voltage is 4,92Vcc.
The company from which I bought the controller tells me I need to feed it through a POE adapter.
Is it normal not to work properly if I only power from the DC plug?
Thank you!
.jpg   LK3 Panel.JPG (Rozmiar: 71.2 KB / Pobrań: 2,867)
