LANController V3, 1Wire DS18B20 and splitter
#18
kollnjak napisał(a):Hello,
Try LK to find IP scan if you do not say so try:
1) connect only PC and LK3 (without router and your pc must be in the same network eg ip address 192.168.1.25)
2) mode bootloader (you have to get jumper)
2) try to upgrade the firmware via ftp (as it is written here in the manual), recording firmware must have the extension .bin!!
3) ftp -> LK3 IP address 192.168.1.255
This procedure worked for me.
Be sure to agree this procedure with the "wilkxt" administrator Smile
Procedure is OK
The LK3 IP address may be the same as it was set earlier
You can watch LK activity (if it start bootloader or not) on your computer via the terminal. You need a USBUART (3,3V) adapter and some terminal program, such as a hyper terminal, realterm or something else.
USBUART e.g http://kamami.com/usb-uart-rs232-convert...results=12
