11-14-2016, 12:14 AM
Wolf82 napisał(a):I think there is no corresponding IP address, it is also the problem.
Here in the forum I read, that using the boot mode, the microcontroller reads of the EEPROM the IP address. This is IP address 192.168.1.100.
I tried this IP address. Did not work, unfortunately.
Thanks for your help!
Zoltan
The IP address is 192.168.1.100, if there was a previously set, but maybe it was set to another, and you don't now it.
You may scan (change ip) interfeces network( with LK) on port tftp (69) and observe in wireshark if LK responde by ethernet frame.
Or if you have eeprom programer, write from address 2, four byte with IP value. When you write eeprom you must keep with reset MCU.
