09-14-2016, 09:46 AM
oasisone napisał(a):Hello,Do you have set histerezes?
i was looking for a solution to monitor more locations and got across the LAn controller, great board, except some problems:
1.in the events config, the mailing option is functioning rather bad, for example, for a temperature of 32 - 27 'C when the temp grows from 25 to 33 'C i get 2 emails with same text (as set in field) and when the temperature drops from 33 to 25 'C i get again 2 emails. The emails should be sent only when going out of the temperature space set.
oasisone napisał(a):2. when setting the option SNMP Trap the board stops responding and needs to be rebooted.We check it
