09-19-2013, 10:01 AM
I have tried to upload new firmware 3.11 and then also 3.12 to have support of more than 4 digital sensors.
But the outcome was, that LanControler with both versions was ignoring settings in EventsConfig page in webconfigurator. The values were
Histeresis = 1
Up textbox in OutX-InpY mapping = 0
Down textbox in OutX-InpY mapping = 22
In firmware 3.01 it worked simply, when the InpY value reached 22 degrees C, it swithced off appropriate OutX. When the temp was lower then 21 it was switched on (22 cut of - 1 hysteresis = 21).
But with new firmware this does not work and the OutX is simply On all the time, even if reaching 22, 23, 24 degrees. I thought that the mapping between the InpY and sensors is somehow switched, but all sensors reached temp over 22 and none of the OutX was cut Off. When I downgraded back to firmware 3.01 everything is working fine again.
Histeresis = 1
