BMS Li-ion battery via Modbus
Check if your LK3 is reading the current as unsigned; changing it to signed (INT16) should display negative values correctly. Some BMS systems also use a separate register to indicate charge or discharge mode. If so, you may need to manually adjust the sign based on that register.  Baldi’s Basics Plus
BMS Li-ion battery via Modbus - przez dusanstr - 07-09-2024, 03:37 PM
RE: BMS Li-ion battery via Modbus - przez dusanstr - 07-22-2024, 01:52 PM
RE: BMS Li-ion battery via Modbus - przez stAch - 09-10-2024, 10:40 AM
RE: BMS Li-ion battery via Modbus - przez AaronAnderson - 07-19-2025, 06:38 PM
RE: BMS Li-ion battery via Modbus - przez dusanstr - 08-09-2025, 05:26 PM
RE: BMS Li-ion battery via Modbus - przez 205theost - Wczoraj, 05:28 AM
