05-08-2025, 06:26 AM
(12-21-2024, 07:35 PM)BMA napisał(a): I need to measure voltages from 0V to about 130V, so I am using resistors divider ( R1 =47k, R2=1k ).
How should I properly set up INPA1 in LK4? Or into which input should I connect the measured voltage?
Thank Snow Rider 3D for help
To measure voltages from 0V to 130V using a resistor divider, you can follow these steps:
Resistor Divider Setup
- Resistor Values:
- R1=47kΩR1=47kΩ
- R2=1kΩR2=1kΩ
- R1=47kΩR1=47kΩ
- Voltage Divider Formula:
The output voltage (VoutVout) from the divider can be calculated using:
Vout=Vin×R2R1+R2Vout=Vin×R1+R2R2
For Vin=130VVin=130V:
Vout=130V×1k47k+1k≈2.7VVout=130V×47k+1k1k≈2.7V
Connecting to INPA1
- Connect the Resistor Divider:
- Connect one end of R1R1 to the voltage source (the point where you want to measure the voltage).
- Connect the other end of R1R1 to one end of R2R2.
- Connect the other end of R2R2 to ground.
- Output Voltage:
- The junction between R1R1 and R2R2 will give you the reduced voltage (VoutVout). This is the voltage you will measure.
- Connect to INPA1:
- Connect the output from the junction (between R1R1 and R2R2) to the INPA1 input in LK4.
Safety Considerations
- Ensure that the maximum voltage at the divider output does not exceed the input limits of the INPA1.
- Check the specifications of INPA1 to confirm its maximum input voltage. In your case, it should comfortably handle up to 5V since you're scaling down from 130V.
Final Notes
- Make sure to double-check all connections and calculations before powering up the circuit.
- If you're unsure about the resistor values or the configuration, it's always good to simulate the circuit or consult with someone experienced in circuit design.
