LK V3.8 with PWM hat no longer working?
(12-11-2024, 03:53 PM)abhiwangame napisał(a): If LK V3.8 with PWM Hat has stopped working, follow the following troubleshooting procedures:
Connections: Make sure that the connections between PWM hat and the controller are proper.
Power Supply: Check that the hat and other connected devices get a proper supply of power.
Software: Check whether firmware and LK V3.8 software is up-to-date.
Library Compatibility: The correct libraries such as the Adafruit PWM library are installed and are compatible with the setup.
Test Hat: A basic script to test PWM hat functionality without interference.
Inspect Hardware: Look for signs of damage or overheating on the PWM hat.
Logs and Errors: Review error logs for specific issues.
For further issues, refer to the official documentation or seek the support of the manufacturer.
you are using an old overlay - check/uncheck low status -
check if the on/off mode works
deselect the regulator
switch the language to PL, make the appropriate settings and return to English
LK V3.8 with PWM hat no longer working? - przez vandariu - 12-10-2024, 11:33 PM
