watchdog issues in LK4
Another thing that I have observed was that the watchdog itself is STOPPED when the RESTART limit is reached and it does not start running again, unless the LK4 reboots or the user press the SAVE button in the web interface(i.e resets the restart counter).
In the current scenario, even if you fix the disconnection issue, the LK4 does not protect the device any more, the watchdog stays off.
This is not optimal.
watchdog issues in LK4 - przez kkontak - 07-01-2024, 11:39 AM
RE: watchdog issues in LK4 - przez kkontak - 07-12-2024, 10:21 AM
RE: watchdog issues in LK4 - przez kkontak - 11-06-2024, 10:34 AM
RE: watchdog issues in LK4 - przez kkontak - 03-21-2025, 03:16 PM
RE: watchdog issues in LK4 - przez kkontak - 07-17-2025, 11:11 AM
RE: watchdog issues in LK4 - przez tonymony - 07-18-2025, 02:36 PM
