watchdog restart limit in LK3.8
Another thing that I have observed was that the watchdog itself is STOPPED when the RESTART limit is reached and it does not start running again, unless the LK3.8 reboots or the user press the SAVE button in the web interface(i.e resets the restart counter).
In the current scenario, even if you fix the disconnection issue, the LK3.8 does not protect the device any more, the watchdog stays off.
This is not optimal.
watchdog restart limit in LK3.8 - przez kkontak - 07-01-2024, 11:03 AM
RE: watchdog restart limit in LK3.8 - przez kkontak - 07-12-2024, 10:19 AM
RE: watchdog restart limit in LK3.8 - przez kkontak - 10-29-2024, 12:12 PM
RE: watchdog restart limit in LK3.8 - przez kkontak - 10-08-2025, 11:37 AM
