Temperature sensors' values disappear
(06-15-2023, 03:34 PM)notek napisał(a): Hello Max
What means disappear - the readings are -60 degree?
IF it happen, it means that controller is not able to decode read frames from sensors.
It can be caused by wrong connections but more probably are poor sensors, or long cables.
I newest firmware 1.57a we change little this function, to try more  times (more frames) decode and if not success show -60 after longer time.
Maybe it help, but for reliable measurement system I suggest check sensors first. IF they not work correctly alone it is bad  sign.
Did you buy this sensors from tinycontrol?
Hello Notek,
the value are not -60 degrees, but rather null. The situation lasts for 5 till 16 seconds approx. and then the temperature value come back again. In UI it looks like this:
[Obrazek: yB3m1f.jpg]
As I wrote earlier, this started to happen 2-3weeks ago, before that there was no problem at all. The sensors are original LANKON-070.
I have bought another LK3.8, I'm going to try to change the device for a new one. I can flash it with new 1.57a firmware, if you recommend that.
Any other ideas?
Thank you!
Best regards
MaX
Temperature sensors' values disappear - przez maxvatar - 06-12-2023, 03:15 PM
RE: Temperature sensors' values disappear - przez notek - 06-15-2023, 03:34 PM
RE: Temperature sensors' values disappear - przez maxvatar - 06-15-2023, 04:29 PM
