Temperature sensors' values disappear
Hello Max
What means disappear - the readings are -60 degree?
IF it happen, it means that controller is not able to decode read frames from sensors.
It can be caused by wrong connections but more probably are poor sensors, or long cables.
I newest firmware 1.57a we change little this function, to try more times (more frames) decode and if not success show -60 after longer time.
Maybe it help, but for reliable measurement system I suggest check sensors first. IF they not work correctly alone it is bad sign.
Did you buy this sensors from tinycontrol?
Temperature sensors' values disappear - przez maxvatar - 06-12-2023, 03:15 PM
RE: Temperature sensors' values disappear - przez notek - 06-15-2023, 03:34 PM
