Sofar ME3000SP Modbus
Hello,
I have a problem in comunication via RS485
I have LanKontroler v3.8 soft 1.49d with RS485 converter
I have epever xtra4415n and comunication works perfect. I use template on Modbus page.
I try to get data from Sofarsolar ME3000SP and Sofarsolar 3300tl-g3 with no success.
On the ME3000SP is icon RS485, when I connect the cable.
The setup of the Sofar comunication is: ID:12, data bit 8, parity NONE, end bit 1, baudrate 9600
It blink only TX led on the converter.
I try all combination in sofar settings and also custom settings in LK.
Thank for help
Change ID sofar to 1 and tray
(07-18-2022, 11:30 PM)wilkxt napisał(a): Change ID sofar to 1 and tray
Both inverters has ID:01
ME3000SP - no progress
3300TL-G3 - RX and TX flash and it seems, that comunication works.
But on modbus page are zero values.
I try also custom settings without success.
For example, how can I set this register?
SOFAR_REG_GRIDV 0x0206
I try 206, 0x4, INT 16
0x206 reg is hex value, in LK modbus settings reg adres you use dec value, 0x206hex=518dec
Try 518,0x4, INT16
(07-20-2022, 07:38 AM)wilkxt napisał(a): 0x206 reg is hex value, in LK modbus settings reg adres you use dec value, 0x206hex=518dec basket random
Try 518,0x4, INT16
Many thanks, it's worked.
Having trouble with your RS485 connection with Sofarsolar inverters? It sounds like you've got a solid foundation with your LanKontroler and epever setup. Perhaps the Sofar inverters' Modbus implementation differs. Have you tried tweaking the register addresses? It almost feels like navigating the levels in ragdoll archers - sometimes you need to adjust your angle (or Modbus settings) just right to hit the target! Keep experimenting, and hopefully, you'll get those inverters talking.
It's interesting you're having trouble with the Sofarsolar inverters. I've seen similar RS485 issues before, and sometimes it comes down to subtle address mismatches. Have you tried varying the Modbus ID slightly, even just one or two digits off from 12? Also, just thinking out loud, sometimes it helps to double-check the wiring diagram again – even my Granny old lamp worked only when the wiring was spot on! It might reveal a reversed connection or something overlooked. Hope you sort it out!
The documentation was a labyrinth, each line a cryptic riddle. I eventually uncovered the missing piece, but not before a small part of my soul was dedicated to understanding that perplexing protocol. This experience, while frustrating, ultimately reinforced the importance of thorough documentation and a tenacious approach to troubleshooting; a truly Repo Game of learning.
