relay does not switch on event, email is OK
when i setting events INP3 OUT0 OUT4 (see picture)
[Obrazek: event.png]
first everything works OK - relay switches, email goes.
INP3=22V OUT0 ON
INP3=25V OUT0 OFF
INP3=23.5V OUT4 ON
INP3=20.5V OUT4 OFF
when INP3=22V, email send OK
After some time stop relay be switched (still off), only email works normally (when INP3=22V)
Currently 2.29 firmware, but I tested all the available firmware version - same problem.
It will help me a full reset, load again firmware.
I have 2 pcs of LAN RELAY, both work the same.
thank you for help
mostly relay stop working after a lost connection
ERROR: Connection to board was lost. in browser
manual switch of relay (Set State) and function "autoswitch" work OK
KAPA napisał(a):mostly relay stop working after a lost connection
What is the reason to lose connection?
I do not know.
browser reports: ERROR: Connection to board was lost.
PING is OK.
and by using LAN_Controler_Tools_v1.2.exe I can restart, then again LC is available.
but the relay does not work - no switching events Sad
I have to do a hard reset and sometimes upload firmware.
Can you drop (use wireshark) packet betwen Lk and computer when you lost communication?
connection is not a problem, today the connection was fine, but just do not work the relay.
KAPA napisał(a):connection is not a problem, today the connection was fine, but just do not work the relay.
only OUT0 not work or OUT4 also?
all ports OUT0-OUT4, I have 2 pcs LC, working same.
This soft 2.34 fix lose connection http://tinycontrol.ats.pl/forum/viewtopi...f=2&t=2545. and repair rely switch problem
