MQTT settings problem
Hi, there is something wrong with mqtt settings. When reload the settings, fills with invalid data.
Can you chet it? I tries with 3 different firmware. Thanks
.jpg   Saved.jpg (Rozmiar: 46.95 KB / Pobrań: 2,737)
.jpg   AfterResart.jpg (Rozmiar: 46.68 KB / Pobrań: 2,746)
Hi stuffi
How did you deal with the problem?
I ask because I have the same thing. Whatever I set up in MQTT I still have
When you return to this section, just as you did on Figure 1.
Hi, you should fill all of the fields ( Login, password ) even if not using them ( "Enable log/pass auth" unchecked. )
In this case, not mixing the data when load the configuration.
Hi Stufi.
Bravo! That was it. Thank you very much for this advice.
Tell me, how do you know that?
