LANController V3, 1Wire DS18B20 and splitter
Hi.
Recently we have adquired two LANController V3:http://www.tinycontrol.pl/tinycontrol/en...troler.php. We updated the device with the last firmware ( Firmware V1.34b - 24.04.2017).
We adquired some 1Wire DS18B20 too: http://www.tinycontrol.pl/tinycontrol/en..._1wire.php and a Spliter for 1wire and I2C bus http://www.tinycontrol.pl/tinycontrol/en..._1wire.php
When we connect a DS18B20 directly to INP6, the LANController recognize it perfectly. But wen we connect a DS18B20 throug the splitter, the LANController doesn´t recognize it.
Is there any recommendation about the connection of the sensors?
Thanks in advance and regards from Spain.
You have one DS18B20 ore more? With socket(two socket has white line) in spliter you use?
Hi!
We are trying with a single SD18B20. We tried to connect the extension cord in both white line and black line.
propably spliter is damage
We bought two splitters, and two LANControllers.
The problem is the same with both splitters.
You use only DS18b20 or AM2320 to?
I attach an image.
I have:
- 1 LANController (I checked a second LANController)
- 1 extension cord (I checked a second extensión cord)
- 1 splitter (I checked a second splitter)
- 1 DS18B20 (I checked a second DS18B20)
.jpg   IMG_20170510_162405_HDR.jpg (Rozmiar: 2.76 MB / Pobrań: 2,719)
Try this firmware
.zip   lk3_firmware_1_35b.bin.zip (Rozmiar: 275.69 KB / Pobrań: 843)
With this firmware the LANController does not boot
Hi,
this firmware (V.1,35b) is next oficial beta version for LanControler V3? Why is it here in this topic?
Thx your answer
kollnjak
